Most/least reliable gas boiler
Bill H.
Member Posts: 30
in Gas Heating
What make/model boiler seems to be the most reliable? Least reliable? Please assume installation is correct, and a non-condensing unit to be used with slant fin baseboard emitters. Thanks in advance
What do you have now?
Before determining what boiler have you had a heat loss done. Is the house well insulated, new windows etc.
If you are looking at a non-condensing boiler what efficiency level do you want to reach? Most non condensing are in the mid 80% level. The American boilers such as Burnham and others are all good choices.
Most of the folks here who install will chime in and give you their experiences hopefully.0 -
Bill they all have good days and bad
What is stocked and sold in your area? It is more about the installation and the availability of parts than it is the boiler. I install most major brands as long as they are sold and stocked where I am installing the boiler. Weil Mclain is my go to boiler as they are sold everywhere and the parts are readily available.Cost is what you spend , value is what you get.
cell # 413-841-6726
Buderus
I like Buderus boilers , Well constructed and they use stainless tube burners ... Install with the outdoor rest for additional savings and home comfort .. They use Honeywell gas valves and controls on their non condensing models ..I have enough experience to know , that I dont know it all0 -
Raypak
Raypak residential is an excellent residential package with a built in bypass and no maintnance pump. We have been installing them since they came out. We have had issues on perhaps three in the past decade and half. We always install them P/S. On some installations we use a Tekmar control for outdoor reset,if the client is willing to pay. Remember is not the boiler efficiency that matters as much as system efficiency. We get 10 to 20% savings using this boiler (Properly sized) and installed P/S.
Henry0 -
Trick Question
All are cast iron. All genrally have the same controls. It's not the arrow that should be in question but the indian that installs it. The installer dictates the reliability. How it is installed and how it is sized are crucial to its longevity."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 403 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 680 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
