hvac
tae
Member Posts: 1
i have 8kw strip and only 1 side is heating i have voltage going in and coming out, i have 26amps going in 14amps coming out it is an old trane unit from 1990
Not sure...
What your question is, but it sounds like your heat element is split apart and grounded. Not an uncommon failure with spiral elements.Bob Boan
Current in a circuit
If you are measuring the amperage before and after the heaters and are getting measurements of 26A and 14A respectively, you definitaly have a short to ground somewhere. The current being supplied to a circuit from a distribution panel should be the same as the current returning to the distribution panel. If such is not the case, the current is being lost somewhere.
De-energize the circuit, disconnct the power leads to the heaters and check for resistance/continuity to ground.There was an error rendering this rich post.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
