Humidifier Question
Kungur
Member Posts: 49
in Gas Heating
I have radiant heatpresently heating my house. I also have a gas forced air system. Can I run the forced air system with a humidifier "without" the burner firing?
Depends...
What make and model is your humidifier?Bob Boan
Humidifier Question
I do not have a wholehouse unit at this point. Trying to decide if it is a feasible way to go or should I get "portable" units.
Thanks0 -
Can Be Done...
With a steam or flow-through type humidifier. A flow-through would have to be connected to the hot water line and provision made to energize the fan on a call for humidity. One of Honeywell's TH8000 series thermostats can provide this function, plus humidity control. Their "True Steam" humidifiers have the fan function built in. You would need a humidistat + an isolation relay added with most standard flow-through units.
A flow-through connected to gas water heater should cost less to operate than the steam unit because gas is generally cheaper than electricity for heating water.
I would not use any type of humidifier that has a reservoir, fixed or portable. They are breeding ground for mold and bacteria.Bob Boan
- 87K THE MAIN WALL
- 57 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 388 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
