how to size Heating Boiler with no Btu info on tag. 1960 national boiler
The tag says :
national boiler
sq'steam 1976000
sq'water 10550
sn# 4563
btu:
the info on the btu looks like it was never stamped. this is an atmospheric hot water boiler with two watts 3/4 174a 30 psi relief valves. it has a couple of end suction pumps that pump through it. I am struggling to figure out the size of this unit. it has a couple of 8"-10" stacks on it. nat gas burners on the bottom. this is the heat for an old Catholic school. anyone have any info on this boiler model number? or how to size based on the sq' of water? any help would be appreciated
