CPH
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,648
What is the recommend cph rate for converted gravity hot water systems? Thanks.
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    What was it converted to
    gas, oil etc? Is it a conversion burner or a brand new boiler and if so what is its technology Mod/Con conventiional etc?
  • STEAM DOCTOR
    gravity to pumped
    It started as a gravity hot water system (1899) and was converted to pumped about 20 years ago. The boiler  is about 25 years old and was converted at some point from oil to gas.
  • Ironman
    Ironman Member Posts: 7,943
    Honeywell Recommends...
    1 cph and that is usually what my experience has been. If you have O.D.reset, you might try 2 cph.
    A high mass system has a "flywheel" effect. Takes a lot to get it going and it wants to keep going after the ignition is turned off.
    Bob Boan
