Boiler won't stay lit
BP3
BP3 Member Posts: 7
It's Sunday and my Raypak boiler HSI igniter is inop.  I tried to manually light it to heat up some water for showers etc, but the burner won't stay lit.  I checked the igniter and it is open.  Does the igniter need to be in the circuit and have continuity for it to stay lit?
    Steamhead Member Posts: 18,211
    I believe
    the ignitor is also the flame sensor. So it has to be working.
    Consulting
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    The igniter will
    have to be replaced. The system will not work without it being able to sense the flame.
    Even if a seperate flame sensor is used it will only work for one cycle, you would have to keep relighting it on every call.
