Old-time plumbers nostalgia question,,,,
What is this stuff?,,,,, it is hard like glass,,,, but soft when heated.
I have heard what it "was" used for,,,, what`s your thoughts?  ;-)
No,,,, it`s not the "Blob" in a dormant state :-)
  • bill_105
    bill_105 Posts: 428
    Is it?
    Could it merely be rosin used a sealing wax?
  • Rosin
    Used on our cloth strap-wrenches to gain a good grip with polished chrome, brass or gold-plated trim. Showing my age(G).
  • Devan
    Devan Posts: 135
    Also used
    in treating wiping cloth, back in the day to wipe a lead joint. Keeps the lead from sticking to the cloth. The few times I attempted to wipe that is what I was taught.
  • Unknown
    edited October 2009
    Nope,,
    although bill was very close,,,,,,,,,,
    JD seems to know everything,, (sorry I forgot his ULTRA),, where`s his input?
  • I guess you were teasing ...
    ... but I do not quite understand. I certainly do not know everything. I know less about heating than any of the professionals here. Would you prefer I post less?
  • Moon rocks
    Brought back by Apollo astronuats. I'll be interested to when the first McDopnalds opens it 's first franchise there.
  • bill_105
    bill_105 Posts: 428
    2nd shot
    It's parrafin
  • bill_105
    bill_105 Posts: 428
    How about Bakelite?
    A first synthetic resin whose cousins are ABS and PVC.
  • Ok, Ok,,,,,,,
    I don`t really know,,, but I heard it was used as a cheater the old-timers could use on CI drainage piping that had the odd sand- hole.
    The rosin explanation sounds more professional,, but this stuff is hard, and heating-it-up to apply could burn many a fingers,,,,, then again, so has wiping joints!  :-)
  • My high school chemistry
    If I remember correctly, Bakelite is a phenol-formaldehyde thermosetting plastic.
    PVC is a polymer of vinyl chloride, that is, IIRC thermoplastic.
    ABS is a copolymer of styrene and acrylonitrile, also thermospastic.
    So if they are cousins of Bakelite, they are distant cousins.
  • bill_105
    bill_105 Posts: 428
    Leat me get this straight
    You can remember that Bakelite is some Phenothis,  Formathat, Thermo Plasti whatever and God only knows what? Your instructor must have been a close relative of the current Mr. Google.
    Used in the 78's not 45's or 33's I thought it was a toy oven to make a cake with a light bulb.
  • PaulR
    PaulR Posts: 25
    I'm picturing it as a hydronic sweetener for my Delta T...
    Two lumps please :)
  • Rosin
    If your lead pot was outdoors ( due to smoke and chance of lead popping) the rosin would be added to the molten lead or wiping solder to make the impurities float to the top.
  • EricAune
    EricAune Posts: 432
    Multi-use
    Grandpa used it to clean molten lead, my uncle used it as a thread sealer and a dressing for his strap wrenches.  Other uncle says it worked best to fix a cracked no-hub fitting for an air test.
    I use it as a conversation piece when other plumbers come to the shop.....makes me look like I might not be as wet behind the ears?
    I would not know where to find any so I just use discarded chunks of roofers tar for my (fixable) cracked no-hub fittings and haven't used a strap wrench since I was a second year.
    I like the sweetener idea best.
