Old-time plumbers nostalgia question,,,,
What is this stuff?,,,,, it is hard like glass,,,, but soft when heated.
I have heard what it "was" used for,,,, what`s your thoughts? ;-)
No,,,, it`s not the "Blob" in a dormant state :-)
Is it?
Could it merely be rosin used a sealing wax?0 -
Rosin
Used on our cloth strap-wrenches to gain a good grip with polished chrome, brass or gold-plated trim. Showing my age(G).0 -
Also used
in treating wiping cloth, back in the day to wipe a lead joint. Keeps the lead from sticking to the cloth. The few times I attempted to wipe that is what I was taught.0 -
Nope,,
although bill was very close,,,,,,,,,,
JD seems to know everything,, (sorry I forgot his ULTRA),, where`s his input?0 -
I guess you were teasing ...
... but I do not quite understand. I certainly do not know everything. I know less about heating than any of the professionals here. Would you prefer I post less?0 -
Moon rocks
Brought back by Apollo astronuats. I'll be interested to when the first McDopnalds opens it 's first franchise there.0 -
2nd shot
It's parrafin0 -
How about Bakelite?
A first synthetic resin whose cousins are ABS and PVC.0 -
Ok, Ok,,,,,,,
I don`t really know,,, but I heard it was used as a cheater the old-timers could use on CI drainage piping that had the odd sand- hole.
The rosin explanation sounds more professional,, but this stuff is hard, and heating-it-up to apply could burn many a fingers,,,,, then again, so has wiping joints! :-)0 -
My high school chemistry
If I remember correctly, Bakelite is a phenol-formaldehyde thermosetting plastic.
PVC is a polymer of vinyl chloride, that is, IIRC thermoplastic.
ABS is a copolymer of styrene and acrylonitrile, also thermospastic.
So if they are cousins of Bakelite, they are distant cousins.0 -
Leat me get this straight
You can remember that Bakelite is some Phenothis, Formathat, Thermo Plasti whatever and God only knows what? Your instructor must have been a close relative of the current Mr. Google.
Used in the 78's not 45's or 33's I thought it was a toy oven to make a cake with a light bulb.0 -
I'm picturing it as a hydronic sweetener for my Delta T...
Two lumps please0 -
Rosin
If your lead pot was outdoors ( due to smoke and chance of lead popping) the rosin would be added to the molten lead or wiping solder to make the impurities float to the top.0 -
Multi-use
Grandpa used it to clean molten lead, my uncle used it as a thread sealer and a dressing for his strap wrenches. Other uncle says it worked best to fix a cracked no-hub fitting for an air test.
I use it as a conversation piece when other plumbers come to the shop.....makes me look like I might not be as wet behind the ears?
I would not know where to find any so I just use discarded chunks of roofers tar for my (fixable) cracked no-hub fittings and haven't used a strap wrench since I was a second year.
I like the sweetener idea best.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
