Sensors
J.C.A._3
Member Posts: 2,980
Which/Whos control you use.
Tekmar outdoor sensor boxes have a space built right in for a second sensor. Their (same for Taco) regular 10K thermister snaps right into a set of plastic teeth, right below the included Block. Run a 4 or six wire T-stat wire and have a ball! Chris
Sensors in Parallel
I have a job that has two boilers. I was wondering if I would be able to wire the outdoor sensors in parallel? Boilers are same model.
DobberThere was an error rendering this rich post.
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
