Sensors
J.C.A._3
Member Posts: 2,981
Which/Whos control you use.
Tekmar outdoor sensor boxes have a space built right in for a second sensor. Their (same for Taco) regular 10K thermister snaps right into a set of plastic teeth, right below the included Block. Run a 4 or six wire T-stat wire and have a ball! Chris
Sensors in Parallel
I have a job that has two boilers. I was wondering if I would be able to wire the outdoor sensors in parallel? Boilers are same model.
Thanks
DobberThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
