Calling Dave Yates
Dave Yates (PAH)
Member Posts: 2,162
and don't see any from you. Please re-send. Thanks.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
have you checked your email?
just wondering if you got what I sent you.
Larry0 -
OK
just sent it again. hope this works.0 -
Mucho gracias
I've sent him an e-mail.
Thanks,
Dave
Since we have Dave Yates on the line
I love the public washroom story you wrote for Contractor, I love flush valves, and I love the way you came out as the genius who eyeballed the water pressure. Foolproof.
Just to bore you with my life.
I once had a similar problem. The standing water pressure was around 15 PSI, the flush valves metered each flush just fine even though Sloan says you need 20 PSI minimum, but of course what didn't happen is a proper swirl. For that more pressure was needed. And for that there was a pressure booster pump, but when the pump was on, the flush valves would run on endlessly, and a proper swirl was rarely achieved. My big problem was air bubbles being sucked into the system by a leaky backflow preventer.
Since air is only good for breathing, we fixed the leak, but all this was probably caused by an overpowering pump. I did not check that, I had not read your article. Thanks.
nuttin boring
bout your life! Least ways, not from your posts I've read. No genious here, just a boat-load of common sense to guide me through the canals of life. Soon as I spied that tower, I knew the rosy pressure projection was bunk. As they say liars figure, but figures don't lie!
BTW, speaking of widow-maker vaults..... Today's multiple confined-space entries proved that if you don't test you can't know and if you don't test you might never know - anything ever again! O2 was 16% in the first meter/backflow 10' deep vault - at head height & less near the floor. 15-minutes of ventillation & it was 21.6%. Once in, I walked the probe back to the far recesses and O2 was still above 21%. The hoist & harness is a fun way to get back out & we test it on every occasion.
2nd vault tested A-ok. Same property, just a few hundred feet apart.
That 4-gas tester is worth its weight in gold.
Why do OSHA regs allow the harnessed individual to disconnect while in the pit???
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
