Concrete Floor Radiant Tubing Repair
BigRob
Member Posts: 322
A friend of mine needs help repairing a sliced 1/2" PEX tube. He punctured it somehow while working on some tile. The tubes are embedded in a 1.5" thin slab. He's carefully removed enough concrete and will fill it back in when the repair is complete.
Are there any special considerations regarding the couplings and crimp rings when it comes to the repair tube layout? We have a couple sharkbite couplings and cinch crimp rings. The repair is in a straight section and we'll need to use two couplings due to the damage.
Thanks!
Thanks!
Hi Ironman, just to be clear, I don't mean the push type Sharkbite connecters. I have couplings that require crimp rings.
Let me know if there are better options.0 -
It's Pex A0
My friend just said the floor uses Pex A, but he has a piece of Nibco tubing for the repair. I read conflicting reports on what type of PEX the Nibco is. More evidence for PEX C, though.0
Pex A is expandable. If you have the expander tool and fittings, that's a much better system.
Pex B is NOT expandable.Bob Boan
I use the Viega press couplings for PureFlow pex. They work on all standard Pex A pipe and even are available in 5/16" for Climate Panel or Quick Trak tubing.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
