Seattle Faux Radiant
Paul Pollets
Paul Pollets Member Posts: 3,656
This is a good example of the fine craftsmanship executed by numerous hydronic "masters" in Seattle. Usually in a townhome....
Sea2.JPG 494.5K
kcopp
  • jonny88
    jonny88 Member Posts: 1,139
    They cant blame the boiler on that one
  • Paul Pollets
    I love the wire outlet strip that was tied on to the piping.
    Steamhead Member Posts: 16,866
    "Uhhhhh, Beavis- where does this pipe go? huh-huh...huh-huh...huh-huh"
    "Just bend it around, here, Butt-head.....huh-huh... huh-huh... huh-huh"
    Or.... who dumped that load of spaghetti in the boiler room?
    Consulting
  • Gordy
    Gordy Member Posts: 9,546
    Outlet strips plural....
  • bricksea
    bricksea Member Posts: 13
    That's rich. Here is a picture of a townhouse I looked at in November. For reasons unknown to the builder the house was unable to stay heated when the outdoor temp was below 40 degrees. This is supposed to heat a three story townhouse. Makes it hard to sell a real job if people building houses think these are radiant systems.
  • SWEI
    SWEI Member Posts: 7,356
    Wow.
  • jonny88
    Jack close your eyes.
  • icesailor
    icesailor Member Posts: 7,265
    Nice paint job.
  • icesailor
    That's a keeper. Send that to Fine Homebuilding as a prime example of how it is supposed to be done by contractor/builders.
  • Tinman
    Tinman Member Posts: 2,808
    Wow is right!
    I can't tell you how many jobs I've lost because the decision makers tell me that they're comparing apples to apples...that the other contractor is also using a mod con boiler and the same brand pump, same relay, same type of air separator. Yet, I'm 15-20% higher. My price is just unfair, they say.
    Well, that's why the lists above are so important.
    Look at the job pictures.
    Call the references. They'll confirm that it isn't just pretty, it works better than it ever did or better than what they ever expected. And it does because I did my homework before I stepped on the job...load calculations, pump sizing and selection, supply water temps, piping strategy, control strategy, etc.
    And if there was an issue, I responded immediately. My references will confirm that.
    Sometimes, I don't take on new work just to insure I can properly take care of our existing customers. I don't want to be the biggest contractor but I do want to be considered one of the best.
    In my area you don't have to be licensed to work in the HVAC trade but you do have to be licensed to be an electrician and plumber. This isn't some remote town on the edge of nowhere. This is Chicago. That needs to change.
    Steve Minnich
    SWEIjonny88Zman
  • Paul Pollets
    The owner of this system posted a year ago on this site. It's still not fixed. He's Swiss and knows this is not the way it's supposed to be.
    I'd say to the builder/GC: if you think you saved money by hiring the lowball, inexperienced giboni, what it will cost to re-do and legal bills will dwarf what it would have cost to do it right the first time.
    Mark Eatherton
  • STEVEusaPA
    Red and yellow and pink and green.........purple and orange and blue...........(I can pipe a rainbow..........pipe a rainbow......)
  • neilc
    neilc Member Posts: 2,705
    maybe the power strips were there to provide proper circuit interruption, or surge protection, or a local disconnect, or , , ,
    known to beat dead horses
  • Weezbo
    Weezbo Member Posts: 6,232
    Swei i am with you on that.
    I do not seem to have enough experience to determine what that 3/4" pvc from the pop off routed 90 X90 X90X90 X90 back into the boiler does...Water saver? is this New style bent handle school , Paul ?
  • Paul Pollets
    Combi unit has 2 relief valves routed into same PVC piping and out the back wall
