huge wrenches for radiator spud couplers
randallkc
Member Posts: 38
ok. I am tired of using pipe wrenches on my spud couplers to un-hook rads. I don't like the damage they do to the couplers. I need a huge adjustable wrench or something.
What do you guys suggest?
I have an 18" says "Stilson" monkey type wrench with flat smooth jaws. Adjusts like a Cresent wrench. Configured like a pipe wrench, only with the smooth jaws. Goes well over 2". Would post a picture but it is outside in the snow covered truck.0
20" channel lock always does it for me. If it doesn't break loose, I give the radiator a little jiggle and it'll always break free.0
I guess I would go outside if there is a chance to show off tools . My wrong not a Stilson, but made by Diamond.
The oldest one was my grandfather's (1900's?) stays home. (the toothed jaw is a knuckle buster if you try it on a pipe....not sure of its true intended function...single jawed pipe wrench?) Trademark of "B & G"
Then the 18" adjustable made by Diamond, can be adjusted very tight with pliers on the adjust nut. This one used a lot.
Rigid hex wrench #11...very handy.
Rigid offset hex wrench # E-110 (like a gun in Texas, don't always need one, but if you do, you need it bad)
The fine German Knipex, sweet parallel jaws up to 1 3/4".
The big guys are handy to crack nuts on a flush valve, just don't drop it into the china.
The little guys are good to reassemble, with final tighten with big.
Thanks so much! I didn't know about the smooth jaw options that were out there. Home Depot does not have many options.0
We remove a LOT of radiator nuts around here...
These adjustable wrenches made by Billings are the go to wrench at the plant, not my photo but we have a dozen here just like it
At home I also have Knipex pliers wrench pictured above which I find more handy for a myriad of tasks. The jaws are easily adjustable with push button and then you get great lever action with the handles. Seems gimmicky but I can assure you it's a finely crafted German tool with a price tag to match.
Peter Owens
SteamIQ1 -
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
That's what I've been using but I kind of wish I also had one of these as it seems like it would give more bite on the spud nut.Dave0176 said:Ridgid spud wrench
https://www.ridgid.com/us/en/spud-wrench
https://www.ridgid.com/us/en/hex-wrenches
This has been my tool set for radiator spuds since 2012.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
I am fortunate to own both old and new versions of many of these wonderful tools. I suspect my grandfather would be proud to see his Stillson and Ford wrenches still in (semi) regular use.
I will say that the Ridgid E-110 has become a bit of a "secret weapon" in the basic toolbag. Everyone (regardless of trade) should probably own one.1 -
Not for the average homeowner, but I have open- and box-end wrenches up to 3.75" for work. That's what I've used on my radiators. Only downside: They are HEAVY.Ford Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems0 -
I have a set of Klutch adjustable wrenches that I got from Northerntool.com. The 3 piece set is 15", 18" and 24" long and they work great for those spud nuts. They also have a life time warranty and are reasonably priced.0
Large but short open wrenches are available. May be called pump service wrenches? Handy for bicycle work as well.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
