Thatcher furnace
vintagefurnace
Member Posts: 14
I have a vintage Thatcher Model G-70 series 1 gas furnace steam. It is leaking water from the rear of the unit. Can the unit part that is leaking be replaced?. If so, where can I buy the parts? Or, at worst, where can I buy a similar Thatcher unit in good condition? Thank you.
How about another system in good condition , if not , then for the parts0
Is it possible to obtain parts for a Thatcher G-70 Series 1 steam boiler? If not, do you know where I might be able to find another Thatcher unit? Thank you.0
Is there some reason why this "vintage" (as you put it) boiler must be repaired, instead of replaced as suggested by the professionals above? Pictures always help.0
No. That company went out of business probably decades ago.vintagefurnace said:Is it possible to obtain parts for a Thatcher G-70 Series 1 steam boiler? If not, do you know where I might be able to find another Thatcher unit? Thank you.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
