How to adjust a Honeywell Vstat?
vaporvac
Member Posts: 1,520
Hi. Just wondering if anyone has pic of how to adjust a newish Honeywell 0-16oz Vstat. I've never had to and it's different to my other one. Honeywell's site is down so I'm asking here. I'm experiencing some super annoying things since starting up my boilers for the season, so just trying to trouble-shoot. Thanks in advance for any help. Colleen
Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF
What's happening? I have the old mercury vapourstat, so I really can't help much -- except sympathise!Br. Jamie, osb
I have a mercury vstat like Jamie but what exactly are you trying to adjust?
3PSI gauge0 -
Are you asking how to adjust it so that the setting is approx correct to the cut out pressure limit? I assume you already know about the adjusting screws on top, right?0
Page 6 shows the adjusting screws on top as Abracadabra said.
http://s3.supplyhouse.com/manuals/1296597322000/46822_PROD_FILE.pdfSingle pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
I have the 0-16 oz Vstat also. There is suppose to be a calibration screw behind that chrome button tab on the back of the Pressuretrol. I have not had to recalibrate my Vstat yet so I can't actually say if it's a hex head or flathead or phillips screw.
PS: Did you clean your pigtail(s) and make sure they aren't plugged?0 -
Thanks guys. I'll check tomorrow. MarkS calibrated mine and set everything before he sent it to me so I've never dealt with it, just read that there's a screw somewhere on other posts. My other one is mercury and just slides up and down. My Vstats are on my header, so no pigtail.
Where to begin with the annoying issues that are new just this year? I'll write about them in a bit in another post.
Happy Halloween everyone!Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Thanks all for the help. I did this today and will check out if it made a difference when it's not 80deg! I think on Saturday. I wonder why they don't put in a little something to turn instead of requiring a screwdriver?Two-pipe Trane vaporvacuum system; 1466 edr
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
