vent manifold
William Faust
William Faust Member Posts: 168
has only 4 ends or openings. What I need is one that has five. That would allow me to place vents at each of the points of the compass. I haven't seen this type of fitting online and I'm guessing that it doesn't exist. I'll call my plumbing supply house this morning and I expect them to laugh at me. Maybe I invented something here.
  • William Faust
    EDITED POST - main vent manifold configuration question
    I will place a manifold on a main with a 6" to 10" nipple. Can I place vents directly on the manifold's horizontal run, or rather should they be atop nipples rising from the horizontal run? If nipples, roughly how long?
    I should have asked this question too although it will probably sound dumb. Instead of using a tee, are there cross-shaped fittings that have five openings instead of tee's three openings? That would make a more compact manifold.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Yes
    and yes. Just make sure the manifold is 6-10 inches up from the main, if there's not enough room for this height just do the best you can.
    The fitting you seek is called a "cross".
    Make sure the horizontal portions of the manifold can drain back to the riser.
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Too late, Bill
    The guys at the supply house lurk here and read your post. They are laughing already. :)
    Seriously, that is an idea, a cross with a tapping perpendicular like a wheel hub.... better get cracking on that. Off to the patent office with ya!
    Another couple of nipples and a tee will give you plenty of options for your venting memorah.
