Question for bill at Honeywell
carol_3
Member Posts: 397
Hi, Bill.
Question for Bill @ Honeywell
Is there a way to change an 8182D over to a cold start control? The boiler now has an indirect instead of a tankless and I was trying to save the customer money.
Darren0 -
There probably is a way, but...
The controls are part of an OEM's package that's approved by AGA, UL, FM or some other regulatory body. Changing it would void the approval, and leave you liable if anything ever went wrong. Probably not what you wanted to hear, but better be safe than in court. Take care.0 -
Thanks Bill
I figured thats what you might say but it was worth a try. Darren0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
