Heater Problem
Leo
Member Posts: 772
Call a Pro. You already paid money for a new thermostat you may not have needed. I have gone into homes that they did the same thing, messed with it all day in a cold house only to call at the end of the day and pay the after hours rate. With in an hour the problem is fixed. It is often times cheaper and quicker to have someone else do it. Most heating systems run flawlessly, when they do break it isn't a simple fix for the user.
Good Luck,
Leo
Good Luck,
Leo
Heater Problem
Suddenly my home heater (forced air gas) stopped working. I thought I had narrowed it down to the thermostat because if I took the batteries out of the thermostat and reinstalled, the heater would work for a while. I installed a brand new thermostat. Initially it worked, but the heater only works for a few minutes (maybe 10-15) and never gets the temperature up. The thermostat thinks it is still commanding heat (says heat on), but nothing happens. If I manually set a temp lower than actual temp, wait for the thermostat to say "heat off" and then reset to a higher temp - it comes on again for a few minutes. It never heats the house up. Any ideas?0 -
Leo's right.
Your problem could be as simple as a heat anticipator adjustment, to a control module inter-safety-lock on the furnace.
These damn things can make a pro frustrated, the danger is; if you blow up the house and kids, who YOU gonn'a take to court? (;-o)0 -
Simple test...
You obviously have enough skill to replace the stat, so this shouldn't be too tough.
Take the two wires going to the stat and wire them together, If your furnace turns on and stays on, its the thermostat that is bad. If the furnace continues to short cycle, then the problem is within the furnace.
ME0 -
Mark
You think these people may have air conditioning?
I suggest they put the red and white wire together.0 -
One big wire nut...
wire everything together, and if every thing turns on at the same time, it's not a thermostat issue...
You're right Jeff, I ASSumed he was dealing with a heating only appliance. I have a tendency to do that seeings as how I usually only work on heating systems...
Thanks for the catch.
ME0 -
Call a Pro!
I did finally call a Pro - bad gas valve. Problem solved! Sometimes it's definitely worth calling the Pro! Thanks for all the input!0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
