Pannel Rads
G. Gibbs
G. Gibbs Member Posts: 30
Dianorm furnishes its radiators with the supply and return tappings in one location. On the “single” radiators which are 2-1/2" deep the tappings are located on the bottom right of each radiator. Dianorm’s “double” radiator is slightly deeper at 3-3/4”, but can be flipped over to allow the tappings to be either on the right or left. These tappings allow for a clean piping arrangement.
Dianorm also furnishes a “rough-in” template with its product that takes the guess work out of positioning the piping. The template also has a built in “U” tube that can be hooked up to the system’s piping so that the contractor can pressure test the system and then install the radiator after all of the other trades have left the job.
Other accessories include a by-pass valve with built-in shutoff and balancing capability made by Oventrop these products can easily can turn your systems to “one pipe” systems. These valves come in about any arrangement you can imagine. Oventrop offers numerous radiator fittings that allow the contractor to use whatever type of pipe they are most comfortable with. The offering includes copper, pex, pex-al-pex or co-pipe, there is also a fitting available for EPDM (Onix)tube. With Dianorm the TRV comes as standard Eqpt, as well as the mtg. bracket. Dianorms also come with a built in air vent and "built in" balancing on the valve side of the radiator.
As far as packaging...I have not seen a Radiator that is packed better. -Greg
  • Nick Dearing
    Nick Dearing Member Posts: 30
    Pannel Rads
    I am changing from forced air heat to a hot water system. I was thinking about using pannel rads because I like the "European" feel of them. I also like constant circulation and TVR's. However, in an existing home, how do you work with pannel rads on the wall with electric, phone, and cable outlets?
  • bigugh_4
    bigugh_4 Member Posts: 405
    Easy, either
    move the rad's or the outlets! Ya sure cannot cut holes in the rads. and if ya wanted and it could be done, but, it'd be mighty expensive. so that leaves moving the outlets, and that is not cheap. That is why desigh has so much trouble here in the states, we have not figured out that total design in a residence is needed. we are still building log cabins compared to the rest of the civilized world. Architechs just do not take the time and interior designers are to busy with wallpaper to do a complete design job. JMO bigugh
  • G. Gibbs
    Panel Rads come in all kind of sizes...do a heatloss first, then pick the rads based on how they will fit the room, I have attached a handy sizing tool you can use. (for Dianorm Rads) There are many other brands on the market, however I
    believe Dianorm gives you more bang for your buck. -Greg
  • G. Gibbs
    Radiators are made...
    in many sizes. First do a heat loss, then pick you rads based on what will fit the room. I've attached a handy sizing tool for Dianorm Radiators. There a many brands you
    can choose from, I believe you will get more bang for your buck with Dianorm. -Greg
  • Jed_2
    Jed_2 Member Posts: 781
    That's great Greg, but
    I get more "bang for the buck" with Biasi Panel Radiators!
    Jed
  • ScottMP
    ScottMP Member Posts: 5,882
  • Ted_9
    Ted_9 Member Posts: 1,718
  • Ted_9
    One needs to be careful when purchasing panel rads. Buderus sends their rads with a bracket, pipe covers and escutcheons. Even the bottom tapings are Euroconus 3/4.
    Most have the built in thermostatic flow setter valve, not the thermostatic head.
    Some companies, like DiaNorn just give the built in flow setter and the brackets to hang it.
    Some companies dont package their rads very well. Buderus does an awesome job of packaging.
    Most are great, just find out what comes in the box and how the unit is set up for piping.
    PATRIOT HEATING & COOLING, INC.
  • Jed_2
  • S Ebels
    S Ebels Member Posts: 2,322
    Check out
    Radson and Vaso radiators at www.hydronicalternatives.com
    They also handle Oventrop TRV's, valve sets and fittings that you'll need for your install.
  • Weezbo
    Weezbo Member Posts: 6,231
    You guys have a great selection of panel rads...
    You would think we would be like "on the cutting edge here in alaska..afterall its colder than a well diggers ....too bad the manufacturers dont have the time to send thier reps here as we are pounding in radiant heating systems by the drove....my ear hears we just bought 67000' feet last month from one of my budies...panel rads from Buderas and myson are represented here yet after looking into the panel rads Mark posted a while back ,there are quite a variety of shapes and sizes that might find a home here in the frozen North....
  • Jed_2
    Biasi Rep for you, Weeze
    Tundra Heating Supply
    P.O. Box 1669
    Bethel, AK 99559
    Ph.: 907-543-5308
    Fax: 907-543-5241
    don't know how close, but.........there it is.
    Jed
  • Jed_2
    All applications don't call
    for actuator heads. There are more uses for panel rads than TRV control. Think a-la-carte!! Pricing is relative.
    Jed
  • leo g_13
    leo g_13 Member Posts: 435
    The thing about Buderus
    rads that I really like, is the supply and return tappings being on the bottom and on the same side! Makes for a very nice install.
    Oh yeah, they work like a charm also!
    Leo G
  • Robert O'Connor_3
    Robert O'Connor_3 Member Posts: 272
    Panel Radiators
    You can try www.runtalnorthamerica.com, they can do anything with panel radiators
  • Ted_9
    Wow Greg, where are you diaNorm rads coming from. Certainly not where I get them. Not only do they not come with the thing you mentioned that they do, they are poorly packaged, compared to say, Buderus.
    The product itself is very good though.
