Taco EBV Valves
ChasMan
Member Posts: 474
Good to hear. I dont do much of this stuff so I want to get it right.
Taco EBV (Formerly ESP Valves) ok to use now?
I ordered 4 of these for a job I am doing. Did I make a mistake or have the issues been resolved with the newer versions?
Also, I like to remove the guts from valves before I sweat them in and then put the guts back? Is this possible with these valves? I guess I will find out. They should be here next week.0 -
EBV valves
Good Morning
The EBV valves you recently purchased should work flawlessly in your system, as long as they are not exposed to extremely high ambient temperatures. Engineering has done a great job supporting the valve, and is currently modifying the power supply making it more robust ensuring the valve operates flawlessly even in the most hostile environments. As you mentioned Taco reengineered the ESP valve several years ago, and since then the valve evolved into the EBV (electronic ball valve), which is synonymous with quality like any other Taco products.
Joe Mattiello
Taco Comfort Solutions0 -
Ok
Well, after reading all of the opinions here, I am willing to give it a shot. Ambient temperatures above a boiler and 2" from a pipe with 180 degree water in it might be a little warm. Especialy in summer. So, the power supplies are failure prone at high temperatures. Not much electronic equipment likes high temperatures or extreme environments. What might be neat is a zone control panel with plug in valve smarts and then just remote the motor, gears, and valve.0 -
I have more than 150 of them installed in my systems without incident. I love em. Nice wiring terminals, extremely low power consumption, and ease of servicing.
You can remove the motor portion of the valve by rotating head about 45 degrees from the body. See instructions..0 -
Taco EBV
I have over 400 installed with maybe only 4 or 5 heads that went bad. Heads were replaced by Taco with no problems. They stand behind their products and are willing to listen to the end use of thier products to make the product better.0 -
You do not have to remove the valve internals before soldering, but leaving the ball in the open position to dissipate the heat while soldering is always recommended.Joe Mattiello
Valves!
Ok, I installed all four and managed not to muck them up. They are all working away. First, they make too much noise, I can hear them on the second floor. Not too bad when you get used to it but it scares the bejeebees out of the cats. One of them wont release right, After pushing the knob in for manual operation, It wont come back out unless I remove it from the valve. Its like the shaft of the valve has a burr on it. Its not the valve though because its only the head that does it. Any ideas?0 -
Taco EBV Valve failure
Just had a customer call me, these have been installed for 2 seasons.
This year the second floor was overheating. Seems that the valve will open but then closes only 45 degrees, this is after some manual rotations. The other one will open, but stays open and will not close.
Would Taco take care of something like this? I still like them and have been installing the new zone sentry models.
Thanks,
Rob Blair Pittsburgh Radiant LLC.0 -
Thanks,
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
