buderus v.s lochinvar
sean_26
Member Posts: 22
which is the better boiler for a single family house?pro and con?it's gas and for a radant system
buderus vs lochnvar
which is the better boiler for a single family house?pro and con?it's gas and for a radant system0 -
Which model?
It all depends. If those were your choices, I would go with stainless over aluminum heat exchangers. Both are good quality machines but I prefer stainless in a condensing boiler if that is your objective."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
lochinvar
If i had to choose it would be Lochinvar. Stainless heat exchanger, No need for external controls, It comes with the primary pump and the outdoor sensor. I have not installed the Buderus mod/con yet but many seem to like it. The Lochinvar now comes wall hung in 4 different sizes, they also have one that modulates from 10,000 to 50,000.
We have installed several lochinvar knights and have had no problems at all.0
- 167 Indoor-Air Quality
