buderus v.s lochinvar
sean_26
Member Posts: 22
which is the better boiler for a single family house?pro and con?it's gas and for a radant system
buderus vs lochnvar
which is the better boiler for a single family house?pro and con?it's gas and for a radant system0 -
Which model?
It all depends. If those were your choices, I would go with stainless over aluminum heat exchangers. Both are good quality machines but I prefer stainless in a condensing boiler if that is your objective."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
lochinvar
If i had to choose it would be Lochinvar. Stainless heat exchanger, No need for external controls, It comes with the primary pump and the outdoor sensor. I have not installed the Buderus mod/con yet but many seem to like it. The Lochinvar now comes wall hung in 4 different sizes, they also have one that modulates from 10,000 to 50,000.
We have installed several lochinvar knights and have had no problems at all.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
