Slab Sensor with hardwoods
What is the max temperature you guys allow your hardwoods to get between the radiant and the base of the wood floor?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
    hot_rod Member Posts: 26,577
    do you mean
    the bottom side of the hardwood? Between the subfloor and underside of the flooring?
    hot rod
