Slab Sensor with hardwoods
Jamie Pompetti_2
Member Posts: 62
What is the max temperature you guys allow your hardwoods to get between the radiant and the base of the wood floor?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
do you mean
the bottom side of the hardwood? Between the subfloor and underside of the flooring?
hot rodBob "hot rod" Rohr
Living the hydronic dream0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
