Hemp
Steve Ebels_3
Member Posts: 1,291
Loctite thread cord. Grainger has it.
Looking for a source
of hemp. NO not that hemp!! Sometimes have trouble between British to I.P.S
Thanks.
Thanks I'll check it oot.
I think.....
It's Loctite #55 IIRC. Much easier to use and neater than hemp.0 -
Is this like
Candle wicking? Fixed many a leak with that (geez alert!)0 -
Ever try
The old standby pipe sealant "Expando", you have to let it set but it works great!
Rich K.0 -
You can use simple hemp twine and untwist. Here's one web source. There are hundreds. You can usually find it at good garden centers as well.
I believe that traditional Oakum using hemp and resin is still available at plumbing houses--at least it is at one here in town. I found Oakum used as a sort of caulk around the basement windows in my 100+ year-old house. Due to position behind external trim I have to believe it's original. Still in perfect condition and doing its job.0 -
ever try
ever try to get something apart thats been expandoed forget about it we use to use wicken lots plumbing supplies have it [ok some do]0 -
how much
Bob i still have some german hemp from a trip aboard years ago i still use it when in a jam or on panel rads ,here's my e mail send me your address and i'll mail you some how many joints are you using it on peace and good luck clammy RDEUZA@aol.com0 -
Expando
If you heat expando with a torch it come right apart.
- 167 Indoor-Air Quality
