oil burner problem
RH_2
Member Posts: 2
About 4 years ago I started working on Burnham LE boiler with a Beckett oil burner. The problem that I am having is that there is constantly soot accumulating on and around the boiler. Now the customer is complaining of a reddish stain on the outside of the chimney chase.
condensing?
Is the boiler by any chance piped with a bypass? It sound's like the boiler return water temp is to low...0 -
Your right ismb. I did not realize it was so important with boiler water temp and bad condesation. Thanks for the info0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
