sealing a copper pipe leak
Big Ed_3
Member Posts: 170
Next time on large fittings pre tin the fittings and copper pipe before soldering . It will save a lot of time .
We recently replaced some 2" and 2 1/2" ball valves on a hot water heating system. Everything went smoothly except that there is a verrry small leak from one of the joints on the ball valve.
Draining that line in order to resolder would not be too difficult, but disassembly would be tough and would require the creation of many more joints. Does any one know of a product or type of solder (brazing?) that would work under these circumstances? (The Rigid/Viega system is starting to look more attractive!!)0 -
try
when i was a greenie i had a slight leak a real small but still a leah my co-worker got his aceline torch hotter than mapp put flux on it and got it to take with out draining the system worth a try royboy0
- 167 Indoor-Air Quality
