lack of service call voids warranty?
Dan Dietrich
Member Posts: 2
Thanks for the replies. It could have been worse. Only about $275. I don't mind needing the service calls, I just wish that he had clearly spelled it out at the time of installation, or had his office call me in the fall to ask me if I wanted the service. good follow up makes for happy customers and profit.
Warranty voided?
I had a new peerless steam boiler installed three years ago. This year it wouldn't fire, so I called the installer. He need to replace a sensor and says my warranty is void because I haven't had a service plan in place. He never mentioned this when installing the system, and I feel a little ripped off. Is this normal practice?
By the way, I own and have read several books from this site. I truly have benefited from them. Thanks0 -
The installer's response sounds a bit short. Maybe he meant that a service plan would have covered this part. But read your warranty card carefully. What sensor? Many parts have only a one year warranty even if the cast iron block has a lifetime warranty.0 -
SERVICE
I WAS ON A ROUTINE CLEANING NEW FURN. (1) YR OLD ANY WAY I ALWAYS TEST FIRE THEM TO NO ADVAIL IT WOULD NOT EVEN TRY SO I TOLD THE HOMEOWNER TO CALL THE INSTALLER SO I WOULD NOT VOID ANY WARRENTY BUT A BUDDY INSTALLED IT SO SOMETIMES U SAVE A $BUCK NOW AND PAY LATER ALWAYS GET A REPTIBLE CO. TO DO YORR WORK0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
