lack of service call voids warranty?
Thanks for the replies. It could have been worse. Only about $275. I don't mind needing the service calls, I just wish that he had clearly spelled it out at the time of installation, or had his office call me in the fall to ask me if I wanted the service. good follow up makes for happy customers and profit.
  • Dan  Dietrich
    Dan Dietrich Member Posts: 2
    Warranty voided?
    I had a new peerless steam boiler installed three years ago. This year it wouldn't fire, so I called the installer. He need to replace a sensor and says my warranty is void because I haven't had a service plan in place. He never mentioned this when installing the system, and I feel a little ripped off. Is this normal practice?
    By the way, I own and have read several books from this site. I truly have benefited from them. Thanks
  • bruce_21
    bruce_21 Member Posts: 246
    The installer's response sounds a bit short. Maybe he meant that a service plan would have covered this part. But read your warranty card carefully. What sensor? Many parts have only a one year warranty even if the cast iron block has a lifetime warranty.
  • burnerman_2
    burnerman_2 Member Posts: 297
    SERVICE
    I WAS ON A ROUTINE CLEANING NEW FURN. (1) YR OLD ANY WAY I ALWAYS TEST FIRE THEM TO NO ADVAIL IT WOULD NOT EVEN TRY SO I TOLD THE HOMEOWNER TO CALL THE INSTALLER SO I WOULD NOT VOID ANY WARRENTY BUT A BUDDY INSTALLED IT SO SOMETIMES U SAVE A $BUCK NOW AND PAY LATER ALWAYS GET A REPTIBLE CO. TO DO YORR WORK
