Vacuum Breaker
Joe_8
Joe_8 Member Posts: 32
In Mass vac breakers are on the inlet of the tank to protect the tank from a vaccum back flow devices protect the potable water supply
  • Tom Hughes
    Tom Hughes Member Posts: 21
    Vacuum Breakers
    Do you put a vacuum breaker on the doestic hot water outlet of a storage tank like a Superstor? What is it and what is it for? Who makes them?
    Help!!
  • bob young
    bob young Member Posts: 2,177
    vac. rel. valve
    to prevent the collapse of the tank. watts makes them.
  • STEVE PAUL_3
    STEVE PAUL_3 Member Posts: 126
    vacuum breakers
    Just to clarify, not to break spheres. A vacuum breaker is used to protect potable water from backflow. A vacuum relief valve is (NJ Code) required if any hot water outlets are BELOW the water heating source. This is to prevent forming a vacuum in the vessel and having the reduced pressure cause the water to flash to steam. Steam can make a very loud sound when it explodes.
  • bob young
    back flow devices
    vac. breaker or backflow n/a for supply of dom. h.w. for complete bldg. b.f. put rpz after main service control valve & meter. at point of entry.
