Vacuum Breaker
Joe_8
Member Posts: 32
In Mass vac breakers are on the inlet of the tank to protect the tank from a vaccum back flow devices protect the potable water supply
Vacuum Breakers
Do you put a vacuum breaker on the doestic hot water outlet of a storage tank like a Superstor? What is it and what is it for? Who makes them?
Help!!0 -
vac. rel. valve
to prevent the collapse of the tank. watts makes them.0 -
vacuum breakers
Just to clarify, not to break spheres. A vacuum breaker is used to protect potable water from backflow. A vacuum relief valve is (NJ Code) required if any hot water outlets are BELOW the water heating source. This is to prevent forming a vacuum in the vessel and having the reduced pressure cause the water to flash to steam. Steam can make a very loud sound when it explodes.0 -
back flow devices
vac. breaker or backflow n/a for supply of dom. h.w. for complete bldg. b.f. put rpz after main service control valve & meter. at point of entry.0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
