Flue Temperature
Roland_4
Member Posts: 84
G'morning,
I'm going to have a Burnham PVG-4 boiler installed. What is the approximate flue gas temperature for such a unit. It is rated at 85.4% AFUE and 90000Btu output.
Thanks
Thanks
If the boiler is running correctly the minimum flue temperature should be 170 degrees higher than the water temperature then usually no more than 270 degrees higher than the water temperature. Anything less is underfired, anything more is usually poor transfer or overfired.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
