Taco 1400 pumps
Matt_32
Member Posts: 8
Does anybody have any experiance with these pumps? I'm considering using one for a job (1400-10) and I like the curve chart for the models. They seem to fill some niche gaps in the 00 series line.
Regards,
Matt
Regards,
Matt
Very Good
I have used 1400-10, 1400-20, and 1400-30 and all have worked very nice. Much smaller than other circulators that I had to use for the same type jobs. Just beware on the 1400-30 and up circulators that you need to use a Taco 0012 Flange set with them. the others will take the regular freedom flanges.0 -
1400 series
The 1400 series is a new design with a diverse range of performance curves that is sure to meet your system requirements. For your reference I have attached the catalog, performance curves, submittal data information, and the instruction sheet. This is a well engineered product with the same generous 1 year warranty as the 00 series. Please advise, if you have any questions or concerns.
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
1400-50
WE used them with good results. A compact pump with an impellor that is very thin.Had one get clogged. Use the freedom flanges0
- 167 Indoor-Air Quality
