Taco 1400 pumps
Matt_32
Matt_32 Member Posts: 8
Does anybody have any experiance with these pumps? I'm considering using one for a job (1400-10) and I like the curve chart for the models. They seem to fill some niche gaps in the 00 series line.
Regards,
Matt
  • John Jr
    John Jr Member Posts: 210
    Very Good
    I have used 1400-10, 1400-20, and 1400-30 and all have worked very nice. Much smaller than other circulators that I had to use for the same type jobs. Just beware on the 1400-30 and up circulators that you need to use a Taco 0012 Flange set with them. the others will take the regular freedom flanges.
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    1400 series
    The 1400 series is a new design with a diverse range of performance curves that is sure to meet your system requirements. For your reference I have attached the catalog, performance curves, submittal data information, and the instruction sheet. This is a well engineered product with the same generous 1 year warranty as the 00 series. Please advise, if you have any questions or concerns.
    Taco, Inc.
    Joe Mattiello
    Technical Service Technician
    joemat@taco-hvac.com
    401-942-8000 X 484
    www.taco-hvac.com
    Joe Mattiello
    Taco Comfort Solutions
  • harvey
    harvey Member Posts: 153
    1400-50
    WE used them with good results. A compact pump with an impellor that is very thin.Had one get clogged. Use the freedom flanges
