Flow checks sticking open?
burnerman_2
Member Posts: 297
i have opened them up all the way tapped on them with a hammer and mostly solves the problem like they said rust dirt ect. only thing u can do is completely drain system and flush but then u may miss some so open and tap
Flow checks randomly stick open and heat gravatates thru loop out of control. Any good advice. Ive tried formula #5 additive, no luck. Is there a good cleaner out there. Why does a flow check hang up? Thanks0 -
Rust, corrosion, time...no real reason. I like spring checks on the returns, and IFC type circulators to reduct the risk of rattling & sticking swing check valves.
TimJust a guy running some pipes.0 -
Matt
Tim`s right, but no matter what CV used a good system cleaning will help, I flush mine with TSP, then rinse well after.
Dave0
- 167 Indoor-Air Quality
