Left hand threads on steam radaitor?
tim smith
Member Posts: 2,859
I had a local machine shop make me a couple before and they worked out great.
Left hand threads on steam radiators
Do some single pipe steam radiators have left hand threads?0 -
between sections?
In between sections? Sometimes, old radiators had nipples that twisted both ways. Here's a link -- read the top question:
http://www.heatinghelp.com/newsletter.cfm?Id=20
-Michael
I had a HW rad with left-hand threads. Actually, it was tapped for either. The LH threads were on the largest opening, but plugged with a LH thread bushing, that converted it to 3/4 RH thread. I was told it was to couple rads together with a special dog wrench. Never could find new caps with LH threads.
TJust a guy running some pipes.0 -
if you are talking about the union between the radiator and the valve make sure you are turning it the correct way (coventional thread). The union nut stays on the nipple coming out of the radiator - it is not part of the valve.0 -
any thoughts on brazing a bushing in to the LHT tapping? I have one of these beauties and only need 1.25 tapping. The only left right nipples I have found are 4 " long. This makes for a big radiator in a tight spot.0 -
No as it is with all things that involve a pipe wrench.... This one was a left hand thread. I was told this was a way to attach additional sections to a radiator or additional radiators. Mine had a threaded plug (looked like the end of a beer can) threaded into the lower 2" tapping. It looked like an easy fix to remove it, add a bushing and the new valve. On this radiator the vent was on the same side as the supply and was not heating well. of course the LHT was on the side I wanted to locate the new valve.0 -
If it is a LH thread plug you have, a machine shop will be able to tap a RH thread hole of any size up to the size below your plug. That's what I had done.
- 109 Chimneys & Flues
- 973 Plumbing
- 386 Solar
- 17 Recall Announcements
