If our community has helped you, please consider making a contribution to support this website.  Thanks!
Check received, job well done....
                    Eugene Silberstein 3
                    Member Posts: 1,380
                    Glad it worked out Bob...
How's everything else in MN going?
            Check received, job complete.....
 I never call a job done 'til it's paid. I received a check for repairs to a chiller problem I proposed to you in July. The one about the missing receiver, which is not missing anymore. It did solve the over-pressure problem and allowed the system to run at full capacity for the first time in many years. I recorded a significant reduction in TD across the condenser, 60 degrees F, and a 30# pressure difference in discharge with both compressors
 running! It's amazing what going back to the basics can solve. Thank you, Professor and to all that replied.
 Best Regards.0
            The leaves are.....
 > How's everything
 > else in MN going?
            The leaves on the trees.....
 are beginning to turn and the overnight temps are dropping. Today I passed the biggest pumpkin patch I have ever seen. Pallets of pumpkins ready to be trucked to area stores. Oh, yeah, its heating season again, too. Have a pleasant fall season, Professor, and best regards.0
            Will do...
 And I hope to see you again at the next wetheads gathering, wherever and whenever that may be.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
