system pressure drop
Kevin__Flynn
Member Posts: 74
what pressure are you referring to? If boiler gauge pressure, do you mean 19 psi?
Or do you have a gauge that reads in Bars?
Kevin Flynn
Kevin Flynn
Have a Viessmann atola burner,water pressure in line should be 1.9 but reads below 1.0 .Nothing in manual,what controls the pressure,how is this adjustment affected??thanks.0 -
Yes ,sorry that was 19 psi,now its down to 9 psi.0 -
can you isolate any zones, or the boiler to check for leaks?
TJust a guy running some pipes.0 -
No apparent leaks,would like to know what controls pressure,how to turn this up?0 -
fill the system with water = more pressure. 20lb should be almost too much. I run 10lb on a single story home, 15lb should work for 2 story. may be leaking in the boiler, not apparent.
