system pressure drop
Kevin__Flynn
Member Posts: 74
what pressure are you referring to? If boiler gauge pressure, do you mean 19 psi?
Or do you have a gauge that reads in Bars?
Kevin Flynn
Kevin Flynn
Kevin Flynn
Have a Viessmann atola burner,water pressure in line should be 1.9 but reads below 1.0 .Nothing in manual,what controls the pressure,how is this adjustment affected??thanks.0 -
Yes ,sorry that was 19 psi,now its down to 9 psi.0 -
can you isolate any zones, or the boiler to check for leaks?
TJust a guy running some pipes.0 -
No apparent leaks,would like to know what controls pressure,how to turn this up?0 -
fill the system with water = more pressure. 20lb should be almost too much. I run 10lb on a single story home, 15lb should work for 2 story. may be leaking in the boiler, not apparent.
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 771 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
