system pressure drop
what pressure are you referring to? If boiler gauge pressure, do you mean 19 psi?
Or do you have a gauge that reads in Bars?
Kevin Flynn
  • Tony B.
    Tony B. Member Posts: 3
    Have a Viessmann atola burner,water pressure in line should be 1.9 but reads below 1.0 .Nothing in manual,what controls the pressure,how is this adjustment affected??thanks.
  • Tony B.
    Yes ,sorry that was 19 psi,now its down to 9 psi.
  • Timco
    Timco Member Posts: 3,040
    can you isolate any zones, or the boiler to check for leaks?
    T
    Just a guy running some pipes.
  • Tony B.
    No apparent leaks,would like to know what controls pressure,how to turn this up?
  • Timco
    fill the system with water = more pressure. 20lb should be almost too much. I run 10lb on a single story home, 15lb should work for 2 story. may be leaking in the boiler, not apparent.
    T
