Check received, job well done....
Eugene Silberstein 3
Member Posts: 1,380
Glad it worked out Bob...
How's everything else in MN going?
Check received, job complete.....
I never call a job done 'til it's paid. I received a check for repairs to a chiller problem I proposed to you in July. The one about the missing receiver, which is not missing anymore. It did solve the over-pressure problem and allowed the system to run at full capacity for the first time in many years. I recorded a significant reduction in TD across the condenser, 60 degrees F, and a 30# pressure difference in discharge with both compressors
running! It's amazing what going back to the basics can solve. Thank you, Professor and to all that replied.
Best Regards.0 -
The leaves are.....
> How's everything
> else in MN going?
The leaves on the trees.....
are beginning to turn and the overnight temps are dropping. Today I passed the biggest pumpkin patch I have ever seen. Pallets of pumpkins ready to be trucked to area stores. Oh, yeah, its heating season again, too. Have a pleasant fall season, Professor, and best regards.0 -
Will do...
And I hope to see you again at the next wetheads gathering, wherever and whenever that may be.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
