Check received, job well done....
Glad it worked out Bob...
How's everything else in MN going?
  • Blackoakbob
    Blackoakbob Member Posts: 252
    Check received, job complete.....
    I never call a job done 'til it's paid. I received a check for repairs to a chiller problem I proposed to you in July. The one about the missing receiver, which is not missing anymore. It did solve the over-pressure problem and allowed the system to run at full capacity for the first time in many years. I recorded a significant reduction in TD across the condenser, 60 degrees F, and a 30# pressure difference in discharge with both compressors
    running! It's amazing what going back to the basics can solve. Thank you, Professor and to all that replied.
    Best Regards.
  • Blackoakbob
    The leaves are.....
    > How's everything
    > else in MN going?
  • Blackoakbob
    The leaves on the trees.....
    are beginning to turn and the overnight temps are dropping. Today I passed the biggest pumpkin patch I have ever seen. Pallets of pumpkins ready to be trucked to area stores. Oh, yeah, its heating season again, too. Have a pleasant fall season, Professor, and best regards.
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    Will do...
    And I hope to see you again at the next wetheads gathering, wherever and whenever that may be.
