wirsbo or viega
RoosterBoy
Member Posts: 459
i have a liking for using colour coded zones and the like ..it helps when you make it back to the job what went where ,...takes alot of guess work out of the day.i happen to like rehau also,it is definitely my preference on large homes. i like colour in my life makes life more interesting.for fittings i like wirsbo pls. rehau red for suppls wirsbo white for returns. not even the sheetrockers and painters can camoflauge them :) loops at stations in orange red and white look good .oh,if you want you can use another tact,put Blue rehau over the returns and red rehau over the supply loopends to the valve, then it makes it easy to most what is what at a glance. or if you like wirsbo has red and blue that they sell on shore now also.
i use the water pipes end pieces as sort of a protective sleeve some times for oil lines....have a happy...
wirsbo or viega
does anyone know which of these manufacturers has the most reliable products0 -
You
You won't go wrong with either one. Both are top notch. What are you considering?0 -
wirsbo or viega
i am doing a new project, whole home, in radiant and trying to decide which system to use0 -
I like
Viega's press fit sleeves. Incredibly strong connection. Nice fitting selection also. Special tools required of course.0 -
now that is
a very colorful answer0 -
Wirsbo or Rehau
That would be my coice.0 -
Both have compiled pinicles of radiant componants. I also like Rehau & Kitec a whole lot. You cant go wrong with any of these guys IMO. Im mixing & matching my components and tubing now. Ive got ebony & ivory living in perfect harmony(G) I like the Pextron just as much as the HePexplus. If I'm working outside I use the Black stuff for longer sustained UV protection and if it looks cool up against lighter surface;-)
Wallace Radiant Design
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
