wirsbo or viega
i have a liking for using colour coded zones and the like ..it helps when you make it back to the job what went where ,...takes alot of guess work out of the day.i happen to like rehau also,it is definitely my preference on large homes. i like colour in my life makes life more interesting.for fittings i like wirsbo pls. rehau red for suppls wirsbo white for returns. not even the sheetrockers and painters can camoflauge them :) loops at stations in orange red and white look good .oh,if you want you can use another tact,put Blue rehau over the returns and red rehau over the supply loopends to the valve, then it makes it easy to most what is what at a glance. or if you like wirsbo has red and blue that they sell on shore now also.
i use the water pipes end pieces as sort of a protective sleeve some times for oil lines....have a happy...
