Radiant Floor heat and Bamboo
No problems at all. Bamboo flooring was was on the products used in the original output testing of ThermoFin.
  • Rob Blair
    Rob Blair Member Posts: 227
    Radiant Floor Heat and Bamboo
    I have a person inquiring about the compatibility with Bamboo wood floors. I thought that there was a prior discussion on this forum.
    Any thoughts.
    Rob
  • Glenn Sossin_2
    Glenn Sossin_2 Member Posts: 592
    Bamboo
    It is my understanding, the harder & more dense a wood is, the more dimensionally stable it will be. I've attached a copy of the Janka hardness table. Note that high moisture content woods, the ones you should steer clear of in most instances, are near the bottom of the scale. I would try to verify the species/type of bamboo you are considering and insure where it is on this scale. Try to minimize the width of the planking you are using.
    As with any real wood flooring, a proper heatloss and design is essential to control floor temperatures. Acclimation is critical to the success of any radiant installation.
    Below is a link referring to your exact question.
    http://www.greenhomeguide.com/index.php/knowhow/entry/1087/
    Hope this helps you.
    Glenn
