Hydronic Air Handlers
I have a client for whom I will be making a whole lot of Solar Hot Water. I will also have a boiler system
He has expressed an interest in replacing his gas air handler with a heat only hydronic air handler unit.
Whose product should I look at?
Thanks
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=350&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • tom_49
    tom_49 Posts: 267
    hydro unit
    > boiler system
    > Whose product
    > should I look at?
    > Thanks
    > _A
    > 350&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • tom_49
    tom_49 Posts: 267
    hydro unit
    I like the heat controller units, built in relays for "TT" conection, pretty well built. ADP makes a variable speed a/h, I think there a little flimsy though.
    If you want real nice, youcould go w/ a Carrier var. speed a/h w/ add-on ( aqua-coil , fits right n top of unit)rall quiet. Lots of choices . Good luck .
    Tom
