Hydronic Air Handlers
Man with a question
I have a client for whom I will be making a whole lot of Solar Hot Water. I will also have a boiler system
He has expressed an interest in replacing his gas air handler with a heat only hydronic air handler unit.
Whose product should I look at?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=350&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hydro unit
> boiler system
> Whose product
> should I look at?
> Thanks
> _A
> 350&Step=30"_To Learn More About This
> "Find A Professional"_/A_
hydro unit
I like the heat controller units, built in relays for "TT" conection, pretty well built. ADP makes a variable speed a/h, I think there a little flimsy though.
If you want real nice, youcould go w/ a Carrier var. speed a/h w/ add-on ( aqua-coil , fits right n top of unit)rall quiet. Lots of choices . Good luck .
Tom0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
