If our community has helped you, please consider making a contribution to support this website.  Thanks!
Resealing bushing in steam rad
                    pitman9
                    Member Posts: 74
                    Tape & dope?
We've got a customer with a rad that's leaking a bit. Looks like it's leaking round the threads of the bushing. I told them we'd give it a shot but I'm not sure we'll even be able to get the old bushing out.
 try heat and turn the bushing both ways. I've removes a bunch this way. Watch out for left hand threads also. I use "rectal" seal 5 no leaks yet.0
            Bushings
 Cut the bushing down to the start of the theads with a sawzal at several locations to cave in bushing. Use non oilbase pipe dope with a steam systen and use lamp wick for leak less thread joints.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
