If our community has helped you, please consider making a contribution to support this website.  Thanks!
Engineered subfloor on concrete basement floor?
                    hr
                    Member Posts: 6,106
                    you would want some insulation or a thermal break between the radiant and the old slab.
Various manufactures have different requirements for installing over concrete. Of course you need to be sure that concrete floor does not see water. This would rot the wood, float the floor and wick away all your heat. Be sure you deal with any water issues before you proceed.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
            best radiant subfloor over basement concrete floor
 What is the preferred radiant subfloor/panel products used ontop of basement concrete floors for radiant floor heat? It is dry but subject to normal basement conditions. Also somewhat limited in height. Plans for a floating engineered wood finished floor or carpeting.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
